Most manufacturers recommend rim width that is +/- 1" over the tread face. A 295 has a 9.5" tread face, so 8" is slightly under the desireable range. It does create more sidewall bulge and you may have to run pressure under 30# to get full tread contact. Not ideal, but not the end of the world either.
