Mr P where did you get and which brand is the one you have?....thanks
Eric its a Mopar production alt off of one of the
early 90s models... its a Denso that uses a external reg
You can see it here sorta... I did make the pulley,
it normally has a serpentine pulley
If you get it from a 90-91 b van you can get a double v pulley.
