My converters now use A500 front pump gears and converter snouts. A500's have flats to drive pump gears and eliminate the crack issue. This is the best fix. Have your converter switched to this drive and use late A500 pump gears.
Will the A500 pump gears just drop in the 904 pump housing?
69 Dart
