I can rob a mid 70's Duster
UCA's/prop valve/LCA to spindle mounting bolts & the spindle with everything on the spindle-rotors/bearings/seals/horseshoe adapters/adapter bolts/dust shield. I'd use new (rebuilt) calipers and hoses and ask for '76 calipers as they have a 2.75" bore as opposed to the 2.60" bores on 73-75 A bodies which'll give you more front bias always a good idea. You can interchange/mount the spindles so the calipers can be on front or rear side but mount them on the opposite side of the spindle that the hard line to hose line mounting tab is on so the hose goes thru/past the spindle. Can use the drum/drum M/C just keep it topped off & check that the half next to the firewall has no RPV in the brass cone. 78 volare hoses will give you more length if needed just cutoff HALF of the metal bracket in the middle of that hose. Get the genuine RIBBED banjo bolt washers from MP. I'd suggest high performance pads and a breakin (bed in)procedure. I prefers sliders rather than floating and the 11&3/4" rotors/adapters will give you more brake but as said I think require 15" wheels
