Not so much the filter, the underlying reason that the air grabber base is the same short 2 inch measurement on the 71 and 72 340 and 440 equipped engines is because Chrysler started using the taller sitting thermoquad carb with thicker base. AVS carb sits shorter, thus the taller base was OK.
