I am now finally going to order a new block so my choices are limited to world and the mopar block because they have wedge mounts. Has anyone here run the alum block on the street and were you able to get one with the lifter wholes already drilled.
yes! be aware they may have chinese studs in them with ARP nuts! big thread on that before do a search. change them over to ARP studs.
(world block)
As I stated in that other thread, you cannot just replace them!!!!!!
The crank bores must be re-alinged honed at a minimum after re-torquing to the correct spec if you indeed find this issue. If they don't clean up, its junk.
