Quote: I have a set of PRW roller rockers on Da Beast’s 496 wedge. I have over 350 passes on them with no problems. I check the valves every 100 passes. I usually only find one or two that need to be adjusted and those will only be off a couple thousands. Good rockers for the price.
Do you use the stainless steel Prw Or the Aluminum Rockers, Thanks
