i would say they were incompatible. Im pretty sure the red scuff pad is equal to 220 grit. when you can just scrape it off like it didnt cure its a compatablity issue. I had that happen 1 time when i used ppg base and put sherwin williams clear over it. The clear wouldnt cure.
