Sounds like you need to strip (it all) off and start over to do it right?
This is the best way.
You pretty much have to anyway to reapply the fill primer to get the sanding scratches out. They will keep coming back no matter how many coats of fill primer you put on top. So I would
sand it all off and do it right. Why in the world would skip sanding and a sealer?
