---6 second Zone--- 6.402 @ 206 .952 60' 4.09 1/8 171 2001 bos R.E.D. 528 B-1 W/871 Koffel's Place Lake Erie Monster 6.69 @ 207 Allen Johnson, 2005 Dodge Stratus 500ci PS Hemi 6.49 1/4 4.45 1/8 1.03 60' 85 ss 526 blown alan johnson hemi gator(jerry Farmer va)
---7 second Zone --- 7.16 @206mph Mike T, 15psi of boost, TwinTurbo Daytona, 7.21 @ 193, 1.11 60', Hemifred, turbo Road Runner 7.41 @ 180.01, HMcCandless Jr, 540 indy, dragster. 7.68 @ 179.31, 1.08 60', 572stealth, '92 Dodge Daytona 572 B1MC, torqueflight, 2330# 7.91 @ 181, 1.27 60', valiant65, 65 Valiant, 3319#, twinturbo 353B1BA + lenco 5-speed 7.92 @ 173, 1.15 60' ,70 Cuda 3150# 500 inch Larry Morgan hemi torqueflite 7.95 @ 168.56, 1.173 60' 408 cubes, Indy headed, fuel injected on alcohol,slingshot383
---8 second Zone --- 8.02 @ 174+, The Haze, twin turbo 452", 8.10 @ 169, TS3303, 91 Daytona, 2470# 572 , glide, just motor 8.13 @ 168, 1.165, 412ci all motor, glide, Dodge Omni 8.14 @ 169,with fogger and plate,Leon Hudson, 65 Barracuda 8.15 @166.58, 1.16 60' with 383ci W8 all motor 91 Dodge Daytona 8.178@ 167.12, 1.139 60', B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.24 @ 163, 1.15 60', Rapid588, 93'Dodge Stealth, 2490#, motor only. 8.36 @ 164, JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005# 8.46 @ 160, Moore & Moore 70 Duster, 572 Wedge, Single 4, Glide, No Nitrous 2650 lbs 8.48 @ 160, sp6162, 80 Omni, 2170#, 500cu, Indy-1,/glide. 8.51 @ 157, hemi al588, 588 Hemi, single 4, '69 Dart, #3250 8.52 @ 156.4, 1.17 60',SB412DUSTER 72 Duster,5.33 @ 126-1/8, 4link B/half 2424# 412/W7 NO P/A 8.57 @ 161, W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350# 8.62 @ 157, TwinDick Racing, 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 3340# 8.68 @ 156, "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.76 @ 156 OUTLAWSSAA 1.25 60FT 3120# HEMIDART 8.77 @ 153.16, Gregsdart, 65 dart ,528cu 440-1, 3000#, 2780 den altitude. NA 6/26/04 8.78 @ 160.34mph Lenny Melton 1968 DART 3,540lbs 10.5 ET streets. This is areal street driven car. 8.78 @ 153.71 mph, Pittsburghracer, 91 daytona 499 rb 440-1 unported .690 roller 2400# with driver 8.781@ 155.13, 1.261 60', Hemifred SOX&MARTIN DUSTER 8.79 @ 151, 1.30 60', Bill_LBSR, 68 Dart #3400, Stock Suspension,BFG Drag Radial 8.81 @ 151.4, 1.268 60', STEFF, 70 Challenger, 526" B1, 3378lbs, 29.5 x 10.5 ET Drag, foot brake, ALL MOTOR 8.859@ 151.00, 1.264 60’,Mopar_Racer_99, 68 Charger 572ci 440-1 heads,2880# 2065 den altitude 8.902@ 148.53, 1.244 60', 1974 Beeracuda, 2870 lbs, 499/PG 8 3/4 8.908@ 150.40, 1.245 60', RT540, 69 Coronet, 2840#, 540" B1BS-727TF 8.92@ 148.3, MoparBilly, 70 Challenger 440/eddies, 2880#, 2 stage plate, PG-8 3/4 8.94 @ 150, 1.25 60', B1duster, 498-1, 200 shot, 3000lb, 4.56, 14.5-32s 8.97 @ 150.9 70dustmite440 70 duster 451 3300lb. lots of spray street driven homebuilt hotrod. 8.99 @ 152.00 1.39 60ft,572 Charger, pumpgas, 3850#, street tires, full exhaust, 125 shot
---9 second Zone --- 9.04 @ 147.6 Best Machine 512 B1BS 65 Coronet 3400lbs 1.26 60' 10.5W Foot Braking 9.08 @ 149.75, Megadart, 422" W5 headed sb, all motor, #2540 9.09 @ 148 Moore & Moore, 71 Cuda, 498 Indy Wedge, 2700lbs 9.100@ 149.51, NHRAMARK, 70 Duster, 3050 lbs, 540" Indy 9.14 @ 148, '86 DODGE CHARGER 515 CI INDY MOTOR 2700 POUNDS 9.14 @ 147, Renegade5047, 69 dart 470 cu in, P/G,2520 lbs. 9.16 @ 147.78, Bigcube '69 Dart , 2975#, all motor, Indy -1 557cid 9.17 @ 150, MR P BODY, 405ci, 2430# 9.20 @ 148, 9secondsatellite, '71 satellite, 499" w/ 350 hp nitrous, 3976# 9.27 @ 141.6, 440Jim, 1.251 60', 5.837 @ 115.5, '69 Dart GTS 3160#, 511 CID NA, no roller cam, footbrake 9.33 @ 142, 1.23 60', 1BADLILCHARGER '81 Charger 2300#, 440/727w/brake, Eddys, 9.34 @ 144.97, TheOtherDodge,498, Auto, 3450 lbs, true 10.5 tires, through the mufflers 9.35 @ 144.66, Bad66, '66 Dart GT, 471 B1 stroker...,all throttle no bottle 9.41 @ 148, hemitime,'66 Dodge Charger, 549 Hemi,4020# stock susp, 100 shot, True 10.5 tire 9.43 @ 126, sloride, shutoff @ 1000', 70 cuda 572, Indy's 3500# street trim w/225 shot, 9.99 @ 136 on motor 9.44 @ 145.3 DusterDave '73 Duster 528 HEMI DOT's 3350# Street car 9.48 @ 140.08, 1.270 60', SKR8PN, 93 Daytona 470,3000#,ALL MOTOR, street tires, mufflers w/ POWER WINDOWS!! 9.513 @ 139.32 Dartsport505, #2755, 505cu.in. 1.283 - 60-foot 9.582@ 140.82 Eric, 81 Arrow 2354# tired 440 SR motor..:) 9.59 @ 142, Biginchmotor, 72 Barracuda, 3000#, 500 , 727 no trans brake, super stock springs, 4.30 gear 9.61 @ 140.55, HEMI71GTX... all throttle no bottle, 500ci, 4link, PG, 3075, 4.56's, 440-1's, Megablock, 3075# 9.61 @ 138, acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire 9.72 @ 137.9, a10sec70cuda, '70 hemicuda, pump gas 3800# street car, ALL MOTOR, drag radials 9.79 @ 137.6mph,W8CUDA71, 415w8,3308lbs,leafsprings! 9.82 @ 135.89, Mopargilley, 68 Barracuda, 400" W-2 motor 3170# stock 727 W/brake 4:56gear 11.5 tire 9.83 @ 135 1.31 60ft,493JOHN 3315#,493,pumpgas,no adders, drag radials,street driven. 9.84 @ 134.90, Bumps440. 69GTX 3240#, all motor, 446ci, stageIV iron heads, Footbraker 9.85 @ 135 398-W2 Duster398 9.85 @ 132.2, DCI, 38 Simca 225ci Slant 6/904, 1/8 6.10 @ 109.8, 2315#, Turbo, 12# boost, EFI,Methanol 9.86 @ 137.95, maxwedgemandra63, 1.35 60 ft', 1965 dodge coronet 557 CI stroker 3104 lbs 9.89 @ 136.42, ProSport, 73' Dart sport, 451, E-heads, 727, 1.37 60 ft, 3035#, all motor 9.91 @ 142 mph,440 906 heads, Mrsixpak 9.93 @ 132.97, moparjohn, 1970 GTX 3250 lbs car and driver at 700 air density Route 66 Joliet 9.94 @136.2, 1.43 60 ft,Cudabin, 67 Cuda, 470, Indy-1's, 2,870#, 727 Dana 4.56, 10.5W-31 9.94 @ 133.99, b3422w5, 70 duster, 422w5, 3380#, 727, leafs 9.952@ 131.56, 1.350 60', Sleepyhead416 73 Duster W-5 416 904 Dana 4.88 Ladderbar 2880 lbs 9.96 @ 134, DavidDean, 71 Duster, 5500'DA 413" 904 SB 2850# 6.18 @ 109 1/8 3500'DA 9.97 @ 133.88 340RICK 70 Challenger 416 W5's leafs and street tires all motor 9.978@ 134.24, 1.360 60'(1Bad440)70 Challenger streetcar,footbrake,leafs,Dot's 3460lb .060 440 stock stroke all motor [Email]9.983@133.89[/Email], ChallyL427 440 .055 over w/EZ heads by MCH, ATI convertor, Straightline cam at 3450. '72 Challenger footbracking all motor. New best coming soon! 9.994 @ 131.63 1.351 60 ft. (RBDuster) 73 Duster 446 9.995 @ 131.57 1.36 60ft (max-maniac) 64 Dodge MW on leaf springs and 9" slicks. 3250 w/me in it.
---10 second Zone --- 10.007 @ 132.3 / 6.35 @ 106.72 / 1.401 60' Lic/Tagged 66 Coronet NA 493 (#3740) on 9"ers .018 @ 131.09, almost in 9's 10.03 @ 135 through exhaust on dot tires paul swigart 69 pro street cuda 10.05 @ 133.59, 1.39 60', Duster John, 73 duster, 6.40 @ 107.90 1/8, street car pump gas, mufflers, 10.5"tires,#3400 10.073 @131.42, 440PURSUIT, 1.375 60' 10.08@ 133 BigGreenDodge, 64 Dodge 440 10.08 @ 132, 1.43 60' 64 Dodge (wildcargo) 10.088@ 137.53, 1.556 60', Tig, '74 Challenger, 528ci, Indy -13 heads, 3892# W/D, N/A. 10.09 @ 131.97,Thumperdart,1.41 60 ft,72 dart 3200+, home port Eheads 10.097@ 131.5 J-BODY 498 stage VI Mirada 3380lb 10.12 @ 133.78 1.36 60' Dustinu 71' 340 duster W5398 3250+ 10.14 @ 129.70 70 Challenger 040 over 440 eddie heads .footbrake. 10.19 @ 128 1.32 60FT 10.5 tire 3660LBS John Cope CRT 63 Dodge push button T-brake 10.19 @ 129.63 1.395 60 ft, andradaracing 1970 dart. 3000 lbs w/o me. NO-Transbrake. 10.19 @ 136.77 1.41 60' footbrake Indy head EM block 511 lowdeck Mark Gates, AMC Pacer NA 10.22 @ 132.37, 1.498 60', Clutch, 88 D100, 512ci NA 10.22 @ 131, 1.36 60ft, BigFish69, 440 Cuda 10.23 @ 130.50, 1.41 60', Marvo451 '71 Duster, 451 RB. Iron 452 heads, pump gas, flat tappet cam 10.24 @ 128, 1.36 60', 10sec440, 440RB 452 heads 590cam pump gas 3400# 10.32 @129.01 1.45 60' DaveS 73 Swinger 446 E-heads, Mega-Squirt EFI SS springs Staightline Perf. Cam 10.325@ 128.36, 1.405 60', weedlayer, ugly year, sb Challenger, 3430# 10.33 @ 130.00, 1.52 60' Bubba, '80 Mirada, 440, 3630# 10.40 @ 129.1, a10sec70cuda, 446 cid, 3700#, all motor street car, through mufflers on 10.5" 10.43 @127.23 wyoming, ran at Vegas 4010' density air, 64 Savoy, 493 max wedge 3510 lbs 6.379 @ 107.24 10.45 @ 127, StrokerPost 67 Dart Sedan, 414 SB, 3290#, factory iron heads, all motor. 10.49 @ 128 1.45 60', TC67CUDA,500cid,w/E heads thru mufflers street car on DOT's 10.50 @ 129 KOS Nick 70dart driven to the track,trw flat top,stock rod 446,iron indy head 1050dom 3500#. 10.50 @ 126.68 1.40 60' dustyswinger 73 duster 416sb pumpgas ported cast iron smogger heads 3250# all motor 10.50 @ 127.00, daron 73 duster, sb street car 10.52 @ 130, BB70DUSTER, 400 stock bottom end w/ E heads on squeeze, and on pump gas
10.54 @ 124, 2933lbs 590cam,1968 dart 365ci mildly ported iron heads on alcohol Dare dude 10.58 @ 126.78,1.528, T748, 68 Dart 493 w/MCH CNC Eddies 10.59 @ 124, 1.45 60', mopar65, 65 Plymouth 3500# 446 w/E heads 10.64 @ 124.50, 1.49 60', RVA, 440ci 3165# 10.649 @ 126.45 1.510 60', BBLM23, 69 Dart, 3305lbs w/driver. Street tires, mufflers. 10.65 @ 123.43 1.45 60ft,11secdart 68 Dart,3160lbs,crate 360 W2 heads,904,s/s springs,10 1/2 inch slicks,mufflers, 10.66 @ 126 Mr. Belvedere, 66 Belvedere 470, 3725# 10.66 @ 124.84, 1.51 60'3800lb 67 GTX, 512ci.,s/s springs, dana 60, 4.10 gears, jkgtx 10.68 @ 128.3, 1.54 60', TimMoffett, 69 Charger, 4-speed Street Car, 3900# with full exhaust 10.68 @ 125, 10secGTX 67 GTX 3670# 10.69 @ 126.46, MFR440, '65 Coronet, 446, Max Wedge, Beachy Eng, A&A Trans, 1.50 60', 3535 lbs. 10.72 @ 125.41 1.507 60' 1974 Duster,446, Dap 10.76 @ 124, Mopartony, 68 Dart 470cid, 727 10.77 @ 123.9, 69Dart,1.49 60 ft, 3100 DA 10.78 @ 124 w/ 1.53 60ft... 72Challenger, 4211lbs Challenger w/ 528Hemi, STREETCAR 10.80 @ 124.86, gj69charger, '69 charger, 500cid 10.80 @ 123.1, 1.48-60' , ftbrke, 99.35@ 1/8 mile, Hemiallen, '66 Charger, ~3550# w/ his son Michael driving- not tuned-ootb eddy's-446-trw-sixpac rods-13.3:1-110 octane-shrt-shftd 727 ! 10.86 @ 118, 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven (let off) 10.89 @ 125.8, sunroofgtx, 71GTX, 472 Hemi, 4080# 10.92 at 130.2 1.69 60' Hemi Joel 67 GTX 496 Hemi 4 speed Stock Appearing, F.A.S.T. legal on G70-14 bias plys 10.98 @ 125.98, 1.54 60' 472 Hemi, 71 GTX 3900# SUNROOFGTX 10.98 @ 120.97, 1.48 60', TonyS451, '65 Coronet wagon, pump gas 470" street cruiser, 4020#
---11 second Zone --- 11.01 @ 122.38 , 1.57 60', 493Charger, 68 Charger R/T auto. 493" 3750# w/o driver 11.17 @ 120.56 1.56 60' super451b , 70 Superbee 383 , 3460 lbs. 11.18 @ 123, 1.51 60', fast68plymouth, 68 Satellite, 383, stock 906's, 3550lbs 11.23 @ 118 1.53 60', 68DART360, 904, 3200 lbs, eheads, pump gas, full exhaust, 10" tire, ss springs 11.24 @ 119.3, 1.58 60', ZIPPY '69 GTX Street Car, 451CI, 11.26 @ 120 mph gmeater, 1968 dodge charger, 440 3700 lbs 11.33 @ 118.9, 1.60 60', LAR_414, 1969 Dart GT, 3350# race wt, 414 stroked smallblock w/ factory J heads, solid cam and pump gas 11.346 @ 116 1.482 60'7.132 1/8 StipeHOG 440cu.in. 10.1comp 3300# pump gas 69 Dart 11.35 @118.49 Runner 71 roadrunner 452" ootb e heads comp xe282s cam 11.37 @ 122.19 1.808 60' 67 Charger 383 ironhead RemCharger 11.40 @ 121.80, 1.63 60', aarlucas, '70 cuda, 451"6 PK, 3700#, 2.5" exh sys,pump gas, 3.91, auto 11.40 @ 119.18, w2_360duster, 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020# w/o driver 11.43 @ 119 1.65 60' 440FISH 72 Demon 383stroker(454ci), 4000stall, 3.73, 452heads,hyd. cam, and fuel injection. 11.46 @ 115 1.55 60' Don1 75 Duster 360 3000# w/driver 11.47 @ 116.21 1.63 60' 340srule '70 duster full street trim 11.489 @ 117.81, G-bob, 1.63 60', 3650 lb 67 Coronet, 91 octane pump gas 11.533 @ 116.32, 1.542 60' 6PKBEE 77 Aspen R/T 360/904/4.10 3425# 11.55 @ 116.23 , 1.62 , 60 , 383man's sons 406 Dart pump gas street car. 11.598 @ 106.690 1.67 60' 67 Charger 440 3600# 8to1 iron head pump gas RemCharger 11.60 @ 116-69 superbee 440-6 pack-3800# BEEQUICK 11.62 @ 114 mph, 1.64 60' in a 3300# 69 fast back cuda street car...Phill 11.67 @ 116 RoadRnnr69, 1969 RoadRunner 500 stroker, auto 4:10 gears Street tires, full exhaust , 93 octane. 11.67 @ 116 mph, 1.71 60', 3800 lbs 71 Challenger, 446 pumpgas streetcar, rvoyles 11.702 @ 113.85, CudaDan, 1.565 60 ft, 360 auto 11.708 @ 114.24, 1.674 60', tboomer '64 Dodge 330 sedan, 3460# 446" 3.91 gears... 11.72 @ 113, 440Jim, '73 Cuda, 3700#, hyd cam, 446CID, street 11.76 @113.8, 1.588 60', 77 Volare, 400/727 3660# 11.78 @ 114, Sledgehammer, '71 Dart Swinger, 3470#, 366ci J-headed Small Block 904 Auto on street tires 11.84 @ 117.25 1.755 60` Scatpk 68 GTX 528 Hemi 4spd 354 gear 4175lbs w/driver 10.1 comp 242/242@50 solid cam factory intake TTI Headers 91 octane 11.84 @ 117.10 1.84 60', Jeepmon, '73 Duster 410 CI Small Block, 833 OD 4-speed street car 11.85 @ 116.6, 1.65 60', 68LAR, '68 Road Runner 3926#, 4 SPEED street car 11.934 @ 113.187, 1.67 60', 67Charger, '67 Charger, 440/727 (full man.), 4.10's, 3710# w/ me 11.91 @ 111, 1.634 60', topfueldart, 70 challenger 446, bone stock 906's, hyd cam psyco goofed.
---12 second Zone --- 12:001 @ 110.07, 1.61 60', Slantzilla, '66 Valiant post car, 232 ci Slant, Keith Long full manual 904, 3.91, 150 Top Gun shot, 3250#, Street legal. 12.02 @ 110, 1.58 60', cudadan 12.03 @ 111, 1.72, '66 Fury, 446/727, Edelbrocks, 3800 stall, 4:10's, 3960lbs w/driver Sportfury440 12.07 @ 108, 1.72 60',3250 lbs, Mikesduster, 72 duster, 340, street trim 12.17 @ 108, 1.77 60', dodge_nut, 71 Charger, 440/727 12.19 @ 105.88, 1.595 60', quickd100, 7.621 @ 87.04 1/8 12.305 @ 112, 1.88 60', Jon Smith, 69 charger 493" full street trim, 7.94 @ 90 1/8 12.7 @ 107 69 M Clone 69 Dart 440/727/4.10 full street trim [Email]12.89@101[/Email] '75 Duster 360 stock pretty much with 340 hydralic cam, ATI converter and 3.91 gears. (mom's car) 12.95 @105.94, 1.94 60', PLATINUM6BBL 69-1/2 A12 Road Runner 3972# Pure Stock 14.025@ 96.08 BigGreenDodge, 72 Dart Swinger 318 Auto
