My new best with the new 511 CID engine, solid/flat tappet cam and all (no roller): 9.471 at 138.51 mph
---6 second Zone ---
6.69 @ 207 Allen Johnson, 2005 Dodge Stratus 500ci PS Hemi
6.49 1/4 4.45 1/8 1.03 60' 85 ss 526 blown alan johnson hemi gator(jerry Farmer va)---7 second Zone ---
7.21 @ 193, 1.11 60', Hemifred, turbo Road Runner
7.41 @ 180.01, HMcCandless Jr, 540 indy, dragster.
7.68 @ 179.31, 1.08 60', 572stealth, '92 Dodge Daytona 572 B1MC, torqueflight, 2330#
7.91 @ 181, 1.27 60', valiant65, 65 Valiant, 3319#, twinturbo 353B1BA + lenco 5-speed
7.95 @ 168.56, 1.173 60' 408 cubes, Indy headed, fuel injected on alcohol,slingshot383
---8 second Zone ---
8.02 @ 174+, The Haze, twin turbo 452",
8.13 @ 168, 1.165, 412ci all motor, glide, Dodge Omni
8.14 @ 169,with fogger and plate,Leon Hudson, 65 Barracuda
8.178 @ 167.12, 1.139 60', B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide
8.180 @ 165, SG303, 91 Daytona, 2420# 572 single 4, glide, just motor
8.24 @ 163, 1.15 60', Rapid588, 93'Dodge Stealth, 2490#, motor only.
8.36 @ 164, JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005#
8.48 @ 160, sp6162, 80 Omni, 2170#, 500cu, Indy-1,/glide.
8.52 @ 156.4, 1.17 60',SB412DUSTER 72 Duster,5.33 @ 126-1/8, 4link B/half 2424# 412/W7 NO P/A
8.57 @ 161, W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350#
8.62 @ 157, TwinDick Racing, 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 3340#
8.68 @ 156, "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650#
8.76 @ 156 OUTLAWSSAA 1.25 60FT 3120# HEMIDART
8.77 @ 153.16, Gregsdart, 65 dart ,528cu 440-1, 3000#, 2780 den altitude. NA 6/26/04
8.78 @ 160.34mph Lenny Melton 1968 DART 3,540lbs 10.5 ET streets. This is areal street driven car.
8.78 @ 153.71 mph, Pittsburghracer, 91 daytona 499 rb 440-1 unported .690 roller 2400# with driver
8.781 @ 155.13, 1.261 60', Hemifred SOX&MARTIN DUSTER
8.908 @ 150.40, 1.245 60', RT540, 69 Coronet, 2840#, 540" B1BS-727TF
8.94 at 150, 1.25 60', B1duster, 498-1, 200 shot, 3000lb, 4.56, 14.5-32s
8.97 @ 150.9 70dustmite440 70 duster 451 3300lb. lots of spray street driven homebuilt hotrod.slowest car in the 8's
---9 second Zone ---
9.063 @ 146.23, Beeracuda, 74 Barracuda, 2800#, 499/PG
9.08 @ 149.75, Megadart, 422" W5 headed sb, all motor, #2540
9.096 @ 146.79,MoparRacer99,68 Charger,2900#,547"/pg
9.100 @ 149.51, NHRAMARK, 70 Duster, 3050 lbs, 540" Indy
9.11 @ 145,Bill_LBSR, 68 Dart 3400 lbs 499/PG
9.14 147mph, Renegade5047, 69 dart 470 cu in, P/G,2520 lbs.
9.19 @ 139.66, Bigcube '69 Dart , 2800#, all motor, Indy 557cid
9.27 @ 144.50, 572charger 3850#, pump gas, 10.5street tires /4 1/2 " exhaust w/tail pipes/ 125 hp shot on leaf springs/ driven daily / not a race car !
9.29 @ 143.8, 1.27 60', BEST MACHINE, 65 Coronet 3460# 511,B1BS,10.5W,3.5"X pipe w muffs, All Motor and Foot Brakin
9.33 @ 142, 1.23 60', 1BADLILCHARGER '81 Charger 2300#, 440/727w/brake, Eddys,
9.34 @ 144.97, TheOtherDodge,498, Auto, 3450 lbs, true 10.5 tires, through the mufflers
9.35 @ 144.66, Bad66, '66 Dart GT, 471 B1 stroker...,all throttle no bottle
9.43 @ 126, sloride, shutoff @ 1000', testing 70 cuda 572 indy head 3500# street trim w/225 shot, 9.99 @ 136 on motor
9.47 @ 142.5, MR P BODY, 395 ci W-2 2430#
9.471 @138.5, 1.272 60', 440Jim, '69 Dart GTS, 3170#, 511 CID, no roller cam here!
9.582 @ 140.82 Eric, 81 Arrow 2354# tired 440 SR motor..:)
9.59 @ 142, Biginchmotor, 72 Barracuda, 3000#, 500 inch motor, 727 auto no trans brake, super stock springs, 4.30 gear
9.61 @ 140.55, HEMI71GTX... all throttle no bottle, 500ci, 4link, PG, 3075, 4.56's, 440-1's, Megablock, 3075 with me in it
9.79 137.6mph,W8CUDA71, 415w8,3308lbs,leafsprings!
9.81 @ 137, acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire
9.82 @ 135.89, Mopargilley, 68 Barracuda, 400" W-2 motor 3170# stock 727 W/brake 4:56gear 11.5 tire
9.84 @ 134.90, Bumps440. 69GTX 3240#, all motor, 446ci, stageIV iron heads, Footbraker
9.85 @ 135 398-W2 Duster398
9.85 @ 132.2, DCI, 38 Simca 225ci Slant 6/904, 1/8 6.10 @ 109.8, 2315#, Turobcharged 12# of boost EFI on Methanol
9.91 @ 142 mph,440 906 heads, Mrsixpak
9.93 @ 132.97, moparjohn, 1970 GTX 3250 lbs car and driver at 700 air density Route 66 Joliet
9.94 @ 133.99, b3422w5, 70 duster, 422w5, 3380#, 727, leafs
9.96 @ 134, DavidDean, 71 Duster, 5500'DA 413" 904 SB 2850# 6.18 @ 109 1/8 3500'DA
9.952 @ 131.56, 1.350 60', Sleepyhead416 73 Duster W-5 416 904 Dana 4.88 Ladderbar 2880 lbs
9.96 @ 133.5, ProSport, 73' Dart sport, 451, E-heads, 727, 1.37 60 ft, 3035#, all motor
9.97 @ 133.88 340RICK 70 Challenger 416 W5's leafs and street tires all motor
9.97 @ 135.46 1.36 60ft 493 john, 493" pump gas,street driven, foot brakin and no nitrous
9.978 @134.24, 1.360 60'(1Bad440)70 Challenger streetcar,footbrake,leafs,Dot's 3460lb .060 440 stock stroke all motor
---10 second Zone ---
10.03 @ 135 through exhaust on dot tires paul swigart 69 pro street cuda
10.05 @ 133.59, 1.39 60', Duster John, 73 duster, 6.40 @ 107.90 1/8, street car pump gas, mufflers, 10.5"tires,#3400
10.088 @ 137.53, 1.556 60', Tig, '74 Challenger, 528ci, Indy -13 heads, 3892# W/D, N/A.
10.09 @131.97,Thumperdart,1.41 60 ft,72 dart 3200+, home port Eheads
10.09 @132,sixpakdodge, 1964 Dodge 330, 452, 2995 lbs.
10.097 @ 131.5 J-BODY 498 stage VI Mirada 3380lb
10:14@129.70 70 Challenger 040 over 440 eddie heads .footbrake.
10.19 @ 128 1.32 60FT 10.5 tire 3660LBS John Cope CRT 63 Dodge push button T-brake
10.19 @ 129.63 1.395 60 ft, andradaracing 1970 dart. 3000 lbs w/o me. NO-Transbrake.
10.22 @ 132.37, 1.498 60', Clutch, 88 D100, 512ci NA
10.22 @ 131, 1.36 60ft, BigFish69, 440 Cuda
10.23 @ 130.50, 1.41 60', Marvo451 '71 Duster, 451 RB. Iron 452 heads, pump gas, flat tappet cam
10.24 @ 128, 1.36 60', 10sec440, 440RB 452 heads 590cam pump gas 3400#
10.325 @ 128.36, 1.405 60', weedlayer, ugly year, sb Challenger, 3430#
10.40 @ 129.1, a10sec70cuda, 446 cid, 3700#, all motor street car, through mufflers on 10.5"
10.45 @ 127, StrokerPost 67 Dart Sedan, 414 SB, 3290#, factory iron heads, all motor.
10.50 @ 129 KOS Nick 70dart driven to the track,trw flat top,stock rod 446,iron indy head 1050dom 3500#.
10.50 @ 126.68 1.40 60' dustyswinger 73 duster 416sb pumpgas ported cast iron smogger heads 3250# all motor
10.50 @ 127.00, daron 73 duster, sb street car
10.52 @ 130, BB70DUSTER, 400 stock bottom end w/ E heads on squeeze, and on pump gas
10.52 @ 127, 1.46 60', TC67CUDA,500cid,w/E heads thru mufflers street car on DOT's
10.53 @ 128.5, DaveS 73 Swinger 446 906's auto, S/S springs
10.54 @ 124, 2933lbs 590cam,1968 dart 365ci mildly ported iron heads on alcohol Dare dude
10.58 @ 126.78,1.528, T748, 68 Dart 493 w/MCH CNC Eddies
10.59 @ 124, 1.45 60', mopar65, 65 Plymouth 3500# 446 w/E heads
10.64 @ 124.50, 1.49 60', RVA, 440ci 3165#
10.65 @ 123.43 1.45 60ft 68 Dart,3160lbs,crate 360 W2 heads,904,s/s springs,10 1/2 inch slicks,mufflers, 11secdart
10.68 @ 128.3, 1.54 60', TimMoffett, 69 Charger, 4-speed Street Car, 3900# with full exhaust
10.69 @ 126.46, MFR440, '65 Coronet, 446, Max Wedge, Beachy Eng, A&A Trans, 1.50 60', 3535 lbs.
10.70 @ 125 60' 1.50 3700 race weight 10secGTX
10.76 @ 124, Mopartony, 68 Dart 470cid, 727
10.77 @ 123.9, 69Dart,1.49 60 ft, 3100 DA
10.78 @ 124 w/ 1.53 60ft... 72Challenger, 4211lbs Challenger w/ 528Hemi, STREETCAR
10.86 @ 118, 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven (let off)
10.95 @ 122.22, 1.55 60' Bubba, '80 Mirada, 440, 3615#
10.98 @ 125.98, 1.54 60' 472 Hemi, 71 GTX 3900# SUNROOFGTX
10.98 @ 120.97, 1.48 60', TonyS451, '65 Coronet wagon, pump gas 470" street cruiser, 4020#
---11 second Zone ---
11.01 @ 122.38 , 1.57 60', 493Charger, 68 Charger R/T auto. 493" 3750# w/o driver
11.24 @ 119.3, 1.58 60', ZIPPY '69 GTX Street Car, 451CI,
11.26 @ 119, 1.51 60', fast68plymouth, 68 Satellite, 383, 3675#
11.296 @ 120.209, 1.514 60', Mark Gates, 7.14 1/8, iron head 451/727/3.91 8 3/4 #3765 AMC Pacer
11.33 @ 118.9, 1.60 60', LAR_414, 1969 Dart GT, 3350# race wt, 414 stroked smallblock w/ factory J heads, solid cam and pump gas
11.40 @ 121.80, 1.63 60', aarlucas, '70 cuda, 451"6 PK, 3700#, 2.5" exh sys,pump gas, 3.91, auto
11.40 @ 119.18, w2_360duster, 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020# w/o driver
11.43 @ 119 1.65 60' 440FISH 72 Demon 383stroker(454ci), 4000stall, 3.73, 452heads,hyd. cam, and fuel injection.
11.46 @ 115 1.55 60' Don1 75 Duster 360 3000# w/driver
11.50 @ 115 1.55 60' 68DART360 ,904, 3200 lbs,eheads, pump gas,full exhaust, 10" tire SS springs
[Email]11.533@116.32[/Email] 1.542 60' 6PKBEE 77 Aspen R/T 360/904/4.10 3425#
11.55 @ 116.23 , 1.62 , 60 , 383man's sons 406 Dart pump gas street car.
11.598 @ 106.690 1.67 60' 67 Charger 440 3600# 8to1 iron head pump gas RemCharger
11.60 @ 116-69 superbee 440-6 pack-3800# BEEQUICK
11.61 @ 114.4, 1.63 60', 3655 lb 67 Coronet, G-bob
11.62 @ 114 mph, 1.64 60' in a 3300# 69 fast back cuda street car...Phill
11.67 @ 116 RoadRnnr69, 1969 RoadRunner 500 stroker, auto 4:10 gears Street tires, full exhaust , 93 octane.
11.702 @ 113.85, CudaDan, 1.565 60 ft, 360 auto
11.708 @ 114.24, 1.674 60', tboomer '64 Dodge 330 sedan, 3460# 446" 3.91 gears...
11.72 @ 113, 440Jim, '73 Cuda, 3700#, hyd cam, 446CID, street
11.76 @113.8, 1.588 60', 77 Volare, 400/727 3660#
11.78 @ 114, Sledgehammer, '71 Dart Swinger, 3470#, 366ci J-headed Small Block 904 Auto on street tires
11.80 @ 113.45, Runner 1.645 60' 452ci stock heads xe282s comp solid. 71 roadrunner 3750 lb w/d
11.84 @ 117.25 1.755 60` Scatpk 68 GTX 528 Hemi 4spd 354 gear 4175lbs w/driver 10.1 comp 242/242@50 solid cam factory intake TTI Headers 91 octane
11.85 @ 116.6, 1.65 60', 68LAR, '68 Road Runner 3926#, 4 SPEED street car
11.884 @ 113.07 1.66 60', BBLM23, 69 Dart, 3340lbs w/driver. Street tires, mufflers, 93 octane.
11.934 @ 113.187, 1.67 60', 67Charger, '67 Charger, 440/727 (full man.), 4.10's, 3710# w/ me
11.97 @ 111, 1.65 60', topfueldart, 70 challenger 446, bone stock 906's, hyd cam
psyco goofed.
---12 second Zone ---
12:002 @ 110.07, 1.61 60', Slantzilla, '66 Valiant post car, 232 ci Slant, Keith Long full manual 904, 3.91, 150 Top Gun shot, 3215#
12.02 @ 110, 1.58 60', cudadan
12.03 @ 111, 1.72, '66 Fury, 446/727, Edelbrocks, 3800 stall, 4:10's, 3960lbs w/driver Sportfury440
12.07 @ 108, 1.72 60',3250 lbs, Mikesduster, 72 duster, 340, street trim
12.17 @ 108, 1.77 60', dodge_nut, 71 Charger, 440/727
12.19 @ 105.88, 1.595 60', quickd100, 7.621 @ 87.04 1/8
12.305 @ 112, 1.88 60', Jon Smith, 69 charger 493" full street trim, 7.94 @ 90 1/8
12.7 @ 107 69 M Clone 69 Dart 440/727/4.10 full street trim
12.70 @ 100, sixpakdodge, 72 Dart, 360 auto, heavy tire spin, trans. slipping.
