It is not a rebody as the factory welds are in place up front and the #'s match on body. This car is about as unmolested as I have seen and you can tell by looking at the body panels taken apart it is an original paint car. There are no other layers of paint on the car except black and then on the unibody black covering the green and under the door hinges all their is is green and you can see where the black was cut in around the hinges but not under the hinges.
I have heard several where several workers said cars were reshot alot at the St Louis plant and one of the most common colors was green so it makes sense a unibody was pulled after being shot green and then changed to a not so common color like black. I was wondering if this might have triggered the 7 in the SO# or if that order was in place and they just grabbed what ever shell was on the assembly line and pulled it off to reshot in the odd color combo this car was ordered as?
