A few years back I bought an old 65 Barracuda that someone had installed a straight axle in. The lug pattern was 4 1/2" dodge or ford bolt pattern with drum brakes. I got this to use on an altered wheelbase project but I would like to know what it is to research disc brake options. No pics as of now. Is there an easy way to tell if it was from an A-100 van? Thx...
Just read a similar thread on the HAMB.
http://www.jalopyjournal.com/forum/showthread.php?t=733686&highlight=straight+axle
They mentioned the bolts holding the wheel cylinder went in at a different angle on the Econolines.
The A-100s have 2 different sizes from the axle out. Gotta measure the drum size or failing that measure the bolt widths of the backing plates.
Look at this
http://www.ebay.com/itm/Dodge-A100-64-65-66-67-68-69-70-2200-front-disc-brake-/390403594229
