Should run pretty good. close to 500. I will say if you tighten the lash up a little w/ the 528 it runs better. I tighten a 528 up to .024/.026 and it seemed to have more "range". I don't think w/ the 528 you need to remove the inner spring for break in, they are pretty whimpy cams.
[IMG]http://i66.tinypic.com/pui5j.jpg[/IMG]
Coming soon!!!!
