Broke the sprag like that 2 times. One was a bolt in sprag that uses the stock parts. Those little metal tangs still fold over easy from the rollers. I now have the a&a ultimate sprag as they call it in my trans along with a griner valve body low band apply been running that for a few years now. The ultimate sprag is a more heavy duty peice. Would be interesting to see which one you had.
dont think it was the Ultimate model
The ultimate sprag costs about 200 , A+A sells lots of parts also.
If it was just a normal bolt in sprag and your old sprag was not damaged or loose in the case then it was a total waste or time and money, as you found out.
