Hey Russ, if its not in the oil or on the ground, its in one or two of the holes. If it were mine, I would blockseal it. The moroso ceramic seal works well if you have the time to let it sit long enough. Its a cheap fix to an expensive problem..
where do I find that?
2001 Durango 5.9 Magnum 99 Durango 5.9 Magnum Parting out 99 Durango 5.9,99 Ram 1500 and 98 Ram 1500 5.9 WANTED.Ram Truck,Durango/Dakota parts and parts trucks!!PM Me. GO BUCKS!!!! Go GATORS!!!!
