How can the clutch be shot all of a sudden?
If it's a 3-finger pressure plate, a lever pivot can break suddenly...had two do it to me. If it's a diaphram pressure plate, the diaphram can break with the same suddeness.
Also, the clutch disc lining can break off at the rivets and jam in between the plate and flywheel.
The INTERNET, the MISinformation superhighway
