Well it didnt go well today... let it warm up and all looked good... made a partial pull to 4500 and it made 463 hp and 458ftlbs... it was fat so jetted down 3 jets all around.. made another partial pull and seen it was lean coming off idle so we pulled the PV and plugged it, went up 7 jets, made a 5000 rpm pull and it was down 50 ftlbs... let it stabilize and made another pull going to 5000 and this time had to abort... lost another 50 ftlbs... pulled the filter and cut it open and seen alum partials... they were saying it looked like bearing material so I pulled the pan and a 4 rod caps and a main cap but they were fine.... after that I told them screw it, pull it off the dyno... only thing I can think of is the cam bearings....I'm so pissed right now I wanted to just do a WOT to see what the problem was but that didnt happen... I'll put it back on the stand
Really sorry to hear this Mike. I have patience issues so this stuff can really take us over the top till we take a step back and chill to evaluate the situaltion w/a clear non-angry mindstate. Works for me............sort of You`ll get it and when you do that thing will FLY...............
72 Dart 470 n/a BB stroker street car `THUMPER`...Check me out on FB Dominic Thumper for videos and lots of carb pics......760-900-3895.....
