They also make a joint with the zerk in the center of the main body.Just install that type with the zerk facing towards the axle. Then when you greese it,turn the wheel far right and move truck forward untill you can get to the greese fitting.Then you can easily greese it.If you remember right where the tire is in its rotation you can get it right the first time without moving the truck every time you greese it.
