Yeah, worked on it all day yesterday fine tuning my timing issue...turns out that for some reason the balancer had 2 timing marks and I had the timing so far advanced(accidentally) that I could see the "wrong" timing mark with the timing light. The "wrong" timing mark was telling me that I was at 10 degrees behind when I was actually about 20 degrees advanced anyway, got it figured out and also tuned the stumble out of it. Now for the frustrating part, after the painter sanded the entire passenger side with 1000 grit he decided he had little league baseball he needed to be doing, haven't seen him since , he hasn't even started on the drivers side and he has lots of orange peel to get out. The front and back glass are still not in, the installer says the front window is on back order...sheesh...
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
