i have a 68 plymouth with a 70 383 in it, the car revs up nice but if you get below 2000 rpm it stalls, i can hold it at 2000 rpm but no lower, someone said to disconect a wire on the white ceramick ballast resistor, i did but it may run a little bit better i think but not correct, any info would be greatly appreciated, thanks paul
