Re: Who Has a Big Block That DOESN'T Leak, Show of Hands
[Re: JohnRR]
#1270846
07/20/12 04:16 PM
07/20/12 04:16 PM
Posts: 1,880 Out in Left Field, NY
bobs66440
What kind of crank and retainer are you using?
It's a factory steel crank and 440Source main cap. I read through all the posts regarding this from the past (including all the warnings, etc) and double/triple checked everything to death. As I said, it was totally dry, and I thought I had it beat, but now it's leaking. It also appears to be seeping a little from the head gasket (Cometic MLS) on the driver's side. I spoke to their tech line and they said to try to re-torque the head.
Oil from the head should NOT be in the bellhousing but stranger things have happened. I'd be looking at the main seal first.
I know the main leak isn't coming from the head. I just added that as an additional complaint (I know I'm whiny lol). I checked really good all around the valve cover and it's completely dry. Also checked the intake pan gasket and the oil pressure sending unit. It's definitely coming from the head gasket unfortunately. I did a search and it seems it's not that uncommon with the Cometics.
If it were a Hemi I could see it because there are oil drainbacks on the bottom corners.
Ok the stupid question , why did you use cometics on that engine ?
Because they offered the thinnest gasket (.027" compressed) I needed for my build to get the compression ratio close to what I wanted. They work (supposedly) well with the aluminum heads and a bonus is they don't need to be re-torqued. Of course this situation may shoot that theory down...
Re-torquing the head would involve raising the engine a few inches to get the header off. Not a project I really want to tackle right now...
Entire Thread
bobs66440
07/20/12 04:36 PM
autoxcuda
07/20/12 04:42 PM
Challenger 1
07/20/12 04:43 PM
JohnRR
07/20/12 04:50 PM
Challenger 1
07/20/12 04:52 PM
JohnRR
07/20/12 05:10 PM
HemiRick
07/20/12 05:20 PM
bobs66440
07/20/12 05:43 PM
1969RR
07/20/12 06:12 PM
JohnRR
07/20/12 06:34 PM
lewtot184
07/20/12 06:42 PM
bobs66440
07/20/12 06:54 PM
JohnRR
07/20/12 07:45 PM
bobs66440
07/20/12 08:16 PM
JohnRR
07/20/12 09:07 PM
383man
07/20/12 09:23 PM
hemi71x
07/20/12 09:52 PM
roadhazard
07/20/12 10:25 PM
rth
07/20/12 11:07 PM
bobs66440
07/20/12 11:15 PM
bboogieart
07/20/12 11:26 PM
Dabee
07/21/12 04:29 PM
roadhazard
07/21/12 04:45 PM
bobs66440
07/21/12 07:12 PM
Kern Dog
07/21/12 07:37 PM
Rug_Trucker
07/21/12 08:06 PM
bobs66440
07/21/12 10:19 PM
jcastle1
07/22/12 02:32 AM
bobs66440
09/06/12 05:37 PM
JohnRR
09/06/12 08:10 PM
bobs66440
09/07/12 11:36 AM
Chris2581
09/07/12 06:02 PM
bobs66440
07/20/12 11:27 PM
kidmopar
07/20/12 11:40 PM
fullmetaljacket
07/20/12 11:00 PM
ZIPPY
07/21/12 02:33 AM
ScatPackNick
07/21/12 04:25 AM
72ls5fla
07/21/12 12:18 PM
62maxwgn
07/21/12 12:26 PM
Mr.Yuck
07/21/12 02:59 PM
racer_amx
07/21/12 04:17 PM
Commando1
09/07/12 01:27 PM
JohnRR
09/07/12 02:16 PM
71charger
09/07/12 06:21 PM
