hi
yes by all means you should have a spring in the lower one and a knowen good fan clutch .
your timing curve may need recalabrated .
move your timing up to 16 inital and make dist top out at about 34-36 max .
what is your app cranking comp psi ?
hi stall convertor can also add heat , use a big trany cooler in the air streem !
