Having a hard time keeping the rocker arms adjusted they loosen up won't stay put. Is it possible the screw and lock nut are no good?
Thanks Matt
I have used Indy before, and they are a good cheepy rocker arm. But I never had any problem the nut backing off. How tight are you getting the nut.
