72 Imperial - ran great from 1993 to 2001 and then I put it in dry storage to travel for work.
Fast forward 11 years.
![](/ubbthreads/images/graemlins/bump.gif)
I trailer it to the house and up on jack stands it goes for new leaf springs, new tank, new sending unit, new fuel lines, new carb.
![](/ubbthreads/images/graemlins/2245452-furysmiley.gif)
Test drive around the block and I notice it feels like its dragging when I stop accelerating. I pull it in to the garage and hear the front tires squealing and a screeching.
![](/ubbthreads/images/graemlins/shock.gif)
Mostly the right.
Pull off tires and try to recess puck on right caliper. FROZEN. Going no where.
Peek in master cylinder and front chamber is clear - you can see to the bottom. Back chamber looks like coffee.
I remove the right caliper with hammer assist
![](/ubbthreads/images/graemlins/hammer.gif)
and unscrew rubber brake line. No gravity flow.
I replace master cylinder cover and pump pedal. No flow.
I start car and pump pedal twice; I get a marginal amount of fluid in my drip pan.
I remove the left side caliper and unscrew from rubber brake line. Gravity drip to the tune of about 3 drops per second, and still no flow from right line.
Master cylinder was replaced by me in 1995 and the brakes worked fine all the way til I parked it in 2001.
How do I check the no-flow condition on the right side? Break the line at the rubber-to-steel junction?
Could it have developed blockage in the proportioning valve?
Master cylinder?
The rubber brake line?
What say you?
![](/ubbthreads/images/graemlins/smilie_help.gif)
