mopartony- I cant belive that aluminium headed small block would be so heavy and weight only 100lbs less than 500cid iron headed bigblock with two carbs...But I need to weight my motor to be sure
I found a pic of my motor plate with the tag on it. I have another one coming in the next day or so that should be clearer. EDIT: the pic here is the one the guy I got my motor from. but still 500 pounds.
The one on my motor says 501.
