Nice car man! Definitely different, very nice choice. It looks very similar to mine, except you are missing 2 doors haha. The video you linked says it's a 64, but isn't it a 65? Ours is a 65 but has a 64 grille like yours, I think it looks better that way. The body line on the front fender is usually spread apart a lot more on the 64's.
How much does the car weigh? Ours is 2,500 with me in it. If you are close to the same, 8.50s should be in the mid 8's.
This car weighted almost same or even a bit less with iron headed bigblock motor and with almost 60lbs heavier driver. So with my R5/P7 motor and with me inside it should weight about 270-290lbs less...I quess weight comes about 2300lbs
