maybe I am wrong but didn't the hard tops use the same mounting bracket as the convertibles? Just that the convertibles used the different hole.
Nope, vert is different, it doesn't have the rise built into it, it stays on the lower floor area.... But FWIW I made mine.... I cut up a couple brackets out of parts cars to get the section where the actual bolt goes & I made the section that connects them.. A little welding, a little grinding & there ya go...
"The Armies of our ancestors were lucky, in that they were not trailed by a second army of pencil pushers."
