So what does fenders rusting have to do with the subframe...an 86 Chrysler 5th ave rides very well,,,as good or better then other manufacturers high end cars...ever drive an 86 lincoln ,,or The front wheel drive Caddy.. ????bottom line is for the time the FMJ sub frame worked well...newer stuff should be better and improved handeling..but for the dollar the FMJ does a good job ...I'll say no more !!!
