You already have one thing in your favor. A car/driver combo that will repeat is a real good start. If BOTH are not consistant, you can't tell if a change helps or hurts.
I think Mike is a bit optimistic on his 1.5xx 60' expectation though. I would think at this point you could obtain mid to high 1.6xx with some tuning.
Brian Dunnigan
Maybe... the only thing is he doesnt state the stall
of the conv... but if its near 4000 stall he should
get a 1.60 or better if he changes the set up
