Quote: KD linkage hooked up?? That is what governs the throttle pressure for proper shifting. If not hooked up and adjusted correctly the shifts will be soft and spungy. Also short transmission life.
Sorry, should have mentioned that the throttle pressure linkage is hooked up and adjusted properly - lever is fully engaged at WOT.
