No one carries an off-the-shelf 9.25" spool.
Supposedly, Summers Bros will make a custom spool for $500-$600, however.
Or in a pinch if the posi unit is built like the one I had in a Dana years ago, (two halves, bolts together, friction plates) you can figure out just how thick an extra shim it takes to in effect, lock it up. In the case of the Dana, it took one cut up 3lb coffee can lid!
why not just weld the spiders together?
That has crossed my mind. Just a little "wossed out" to try it.
Fastest 300
