Quote: you need the piece that is shown above to seal the deal...
that part comes with the performer intake from edelbrock for a reason..
That's what I get for buying the intake and carb "used" ... I'll see if I can get that part. I was using a 1" spacer to help reduce heat soak to the carb, but I got rid of it in an effort to reduce vacuum leaks.
Also, to the question about the line across the timing tape on the video.. i think that's just an anomaly with the frame rate of the video and frequency of the flash from the timing light.
