Which brand hydraulic roller lifters are you using
He didn't mention the Roller lifter....only the Roller Rockers
and from the brief installation of the Harland Roller rockers that I have used (for a week now) 2.5 turns is way too much. I was told to use 1/2 a turn after the pushrod stops turning in your hand
You sure you don't have a collapsed lifter? I still have one but the car is gonna sit for a while until I figure out if I am going to remove the intake and rebuild the lifter AGAIN. Or buy another lifter and put it in its place.
Since he said he had a roller cam, I bet he has roller lifters.
