I have wondered about that and checked but I cannot tell. How is the best way to find it if there is a gasket leak?
The head gasket is .052 thick and all the valve train came new from Hughes.
Unless I did not understand I took the nut down on the rocker until the push rod would spin but with resistance (0 pre-load) and then turned it 2.5 times and locked it.
