Quote: I'm a believer in grinding paint off the mounting area so you're grounded properly to bare steel...
Clean steel;a little di-electric;drawn down snug...
Lost one in 20,000 miles...
That's what I did, sanded to bare metal where the box attaches, on both the box and fender. Also used one of those sharp star washers under each bolt. I'm sure there was a good ground.
On the Mirada though, the box bolts directly to the inner fender apron. There's no bracket that allows an air gap. I may add one similar to what my NY'er has.
