pull the belt off and see what happens. I suspect the power steering is bias to one side and needs adjustment.
Warning!!!!!
Please be real careful if you attempt to do this adjustment yourself you can crash and burn really easiliy if you do not do this right.
Also keep your hands away from the steering wheel after making the adjustment. If miss adjusted you can easily break a arm if caught in the steering wheel
Sorry strike all that you went to manual not the other way around
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
