I just had some 20" outers narrowed down to 6" wide and had some 18" outers made into 5" wide at a local shop. Price was $175 per outer including polishing.
Just as an example for you....thier work was top notch as well.
Depending on the bolt pattern, you can also get 1 piece outers that use a bolt in center you know as well.. (so it makes a 2 piece wheel with a 3 piece center basically) You might find one of those that is the right back spacing and width for you perhaps ?
I know another place who just started doing 2 piece outers and the 1 piece outer for 3 piece centers, but not sure what bolt pattern they are..
Come to think of it, the guy I use to CNC cut centers for me had some odd ball bolt pattern 1 piece outers for the 3 piece center laying around too.
