I would use it as is, the floater has a certain wow factor for a pro streeter. just my
Not sure about the spool on the street with a four link.
Don.
Put that rascal in and drive it, if you don't like it you can change next it winter I've used a spool on the street for 7 yrs so far, it is a pain to park in parelel parking or make real short sharp turns but it will turn if you give it enough gas
