A518 with either a JVX adapter or JW Ultrabell.
http://www.cuda-challenger.com/cc/index.php?topic=84774.0Many folks have done it in an e-body w/o hacking the car. Slapstick shifter works too.
I plan on doing the same mod.
I'm just curious on converter...for non-lockup.
They say, that you should get stall speed that's less than what you cruise at 65mph.
With 4.10 gears, and with a .75OD (3.07) and 26" tall tires, that means running 2600RPM. Does that mean I have to get a 2500 stall 'verter? That seems kinda low if you got a hot street engine.
