I wanted a replacement tag so I could put it on the car for shows and keep the original in a safe place. A couple of years ago a friend got his stolen off his car at a local show, I don't want to be in the same position.
On this note, when I heard that tags were being stolen at shows, I decided to replace the two screws with two phillips bolts (with the same size head), and nylocks on the under side. Even for my 'lowly' BS23N car.
A simple screw driver and 5 seconds isn't going to get my tag. Problem solved
