All things considered I think I'm going to go with the felpro 1009's. My new cam is a racer brown custom grind 243@.050 duration and .510" lift. I talked to Jim @ RacerBrown and we decided this is the best cam for my new goals... Do any of you guys use the copper sealer on the 1009's? The last 440 I built I used them with no sealer, but I sold the car shortly after? I had an oil seepage problem with this current stroker so I want to make sure I fix this seepage problem while I'm at it...
"It takes a Mopar to catch a Mopar”
1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54
