Last shot is top down view of previous shot. Used another section of 5/16 brakeline, custom bent to run from outlet of regulator to carb inlet. They only come in 12" and 20" lengths from my local Napa. 12" ws too short to accomodate the bends, and 20" was too long, so had to get the 20" length, cut it, put the fitting back on it, reflare it, and bend it to run to the carb.
Lots of work. And because the hardline has the hose on it for the full length to the regulator, it doesn;t look as factory or elegant as it might, but it's probably a little more functional.
HTH,
Marq
