I welded in a nut and used a bolt to adjust front end travel. Very important on a drag car. I then put traction bar snubber and as many washers as possible on the lower control arm to answer another post about weak drag race torsion bars.
Leon
So you would let your car ride on the bump stops?
Brett Miller W9 cnc'd heads
STR Chassis fabraction
