Side clearance was good. I was running the comp hold downs with arp studs. I am just going with I should not have been running the unbushed ones.
Anyway I think I am going to switch to the Harlond Sharps. On the summit site it says you may have to restrict the oil flow to keep the oil pressure up. Did anyone have to do this? Thanks!
"People Think I'm Insane Because I Am Frowning All The Time" Black Sabbath
