Over the last 40 plus years of racing I have yet to break a front u joint, twisted off drive shafts,never broke a tail shaft , spread rear yokes, blew out lots of rear joints. That $20 dollar universal loop is all you need. NHRA says it must be mounted within 6" of the joint. Keep it centered at 6" from the Joint and the bolts won't catch and tear your stuff.
it's ok to butt heads, just don't do it with a butthead
