Quote: I had the car on my lift I grabbed the end of the loop and it was able to hold myself(200lbs) off the ground... Never budged... I'll get Another pic up
Well that is good enough for me. I withdraw my earlier statement. OR... maybe you should hit it 24 times with a sledge hammer to simulate a broken front driveshaft and see if it moved... Just yanking your chain, if it will hold up 200 lbs, I would think a driveshaft would be no problem.
