Hey Guys been awhile since an update, been pretty busy lately, been working on some other things. Anyways...
Been working on the wheelhouses and trunk extensions, A lot of work went into making these things fit, The trunk extensions fit well, but the wheel tubs inner and out are very poor...
Tubs welded together, seat belt bracket installed. The holes that are pre punched were even close. They were an inch plus off, and thats not including have to cut new metal to make them work
Installed...
Now the passenger side i remembered to take pics of the modifications. The tubs are too long, pushing the trunk extensions down. Therefore the quarters do no fit. It was not too bad to fix, just extra work
I had some rust to fix before on the seat belt bracket and the webbing...
Tubs and trunk extension installed and modified...
