The part number stamped on the case pan rail can be matched up with the parts catalog of the appropriate year and it will tell you exactly how the transmission was assembled/built as by chrysler.
In the 80's chrysler started using the 904 based transmissions alot more in the truck/van line because of fuel economy becoming a more pressing issue. Probably cheaper per transmission as well to mfg.
