I'd have to agree with the rear, but I would also check the motor mounts, as I had one go bad on a my Challenger and when I would jump on it, it would pull hard left ? under normall driving it was fine??? I look at anything, just go over the car with a wrench and check everything look for anything that maybe moving. If its that bad you will see signs of it somewhere.
